Fun 6, Titanium, MM and MR cams.
Sab
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
I've got the above cards and cams. Can someone tell me the best way to maximise these so that I can watch as much as possible please. I'm getting a bit lost in this minefield.
Currently getting 19' 13' and 5'E and 30'W.
MM Penta 1.11 and and Titanium card OS 1.06.
What's wrong with 1W Sab, or are you unable to see it?
Sab
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
rolfw,
I can't get 13' or 1'w at the moment. The signal is there but nothing on the strength. I need a slight adjustment as you mentioned in an earlier post but weather is too cold for me to mess about out there at the moment! I'm getting mixed up with the different types of cards, cams and software to go with them and I'm still a bit confused even after reading inf. in forum.
Ah yes sorry sab, now I remember. :)
The MR should get you everything on 30W, although you need the latest update, otherwise there is a nagra file for the Tit' card which will do the same, it should also get you anything that a 6 in 1 file will on the other satellites.
Sab
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
Thanks rolfw.
I'll give it a try.
