funcard 6
radedef
hello there!
I'm trying to program a funcard 6 with a cas 2 interface (usb). Unfortunately I can't get it working on my x-cam. Can anyone tell me how funcard 6 are programmed? I first write the flash file and then the eprom?
I use some fun6in1 files. It that correct? If no where can I find the correct files?
thanks and cheers!
waverider
Salty Tech Monster Bod
Protek 9750 HD IP, Spiderbox 9000HD. Cryptik Digital H-H Mount with1.2m Oval Dish and a box in the garage consisting of 2 obsolete STBs, various Cards and a couple of cams!
South East England
Normally you would first let the programmer detect the card......Then erase card.....then select and load Flash file.....then load Ext EEp file.......then select write. That should work!
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
ScOrPo said:
euh where can I get the latest fun6in1?
Do a search using Google or another engine
Or look more closely at this forum and use Nobbly's Links
