G-Guard Dish
mfwink1970
I have a G-Guard dish with what seems 3 options to attach LNBF's to. Does anyone have a picture of what the configuration should look like?
Can you supply a picture of what you have?
mfwink1970
No because it is all in pieces on the floor - it seems from what I am being told is that in fact you can use 3 LNB's on the receiver. I am new to this - I have never set up a satellite and I am not in my home country where this would be easy.
mfwink1970
rolfw - it seems that you know about Sky receivers and how to set them up. I would love to be able to contact you with some questions. I have my system set up but I am not finding a satellite. I also do not know if I need a card or not. I am temporarly working in Iraq and bought one of these systems.
You are not going to pick up much from Sky at 28.2E from Iraq, unless you have a very big dish, what size is the dish?
Don't think that you'll get anything from SkyUK, may be better pointing it at 13E.
mfwink1970
I was told to try 200 degress true North and look for the Hotbird satellite. The problem is I do not know if I am getting the dish turned correctly or how to tune it. I know they work here because many have them I just can't seem to figure out how to set one up. As you can imagine it did not come with instructions. The unit also did not have a card in it, I was told that I would not need one here.
Go to www.heavens-above.com and get your coordinates, then download the swedish microhace calculator from www.smw.se, punch in the coordinates and the satellite location, it will give you azimuth, elevation and LNB skew.
PS. What receiver do you have?
Does the receiver have any sort of decryption onboard, it isn't one I know of.
mfwink1970
It is supposed to but I am not sure - I went to Heavans Above and got my cordinates but I do not know where they are to be entered. I also got the Hotbird 4 wideband footprint - It says 13 degrees E. is that east or elevation?
That is 13 degrees East of 0 degrees longitude. I'm assuming that your lattitude will be around 44 degrees East, so the satellite would be 31 degrees west of due South for you.
You need to put the coordinates into the Swedish Microwave calculator, there is a space for lattitude and longitude and satellite location.
sad85man
g-guard 9500 fta plus 2m
