Gibertini or orbital 1M dish?
geordiejohn
Sky sd and penta 85cm motorised with ancient spiderbox 900HD
uk
Hi all,a little advice needed please.
I have a 90cm triax dish and technomate 2100 a motor on a temporary mount (heavy duty speaker tripod with feet weighed down).
Unfortunately, due to my own stupidity this recently fell over and the dish was considerably bent, my next mount will be 2" scaffold with plenty of brackets!
I have straightened the dish as best i can,but some of the weaker channels have gone, for example i can no longer get anything from 26 East.So i am looking for a new dish,probably either the 1M orbital which i can get locally for £70 or the gibertini which will probably cost about £15 more delivered.
I always prefer to but things over the counter,that way any problems can be easily resolved,plus i have used this local guy before and service is very good.Does any one know of a northeast (tyneside) gibertini stockist?
Cheers!
satelliteman
Gibertini for sure but also consider the PENTA 85cm dish
SM
I would personally pay the extra for the Gilbertini, not convinced about the Orbital dishes, or perhaps try the Penta 85, the performance won't be far off the Gilbertini and is great for 16E..
geordiejohn
uk
thanks for the quick replies,happy to pay the extra £15 but would rather pick it up myself,had some bad experiences with parcel couriers!would the Penta 85 be ok,i like hunting for channels on the fringe, roughly 45e to 45 w for me?
satelliteman
It will perform as good as some 1M dishes :)
divibi
dvb-s pci card
85 cm offset dish
London
Yes, but give it a try from 70e to 70w, you may be lucky.:)
geordiejohn
uk
only if i demolish several local buidlings first!
wod
yorkshire
what dish have you bought then ?
Milkybarkid
I had an Orbital 1M and my 85cm Gilbertini was better reception.
geordiejohn
uk
Nowt yet, only asked yesterday,tempted by the penta 85 cm as i reckon i could get away with permenantly mounting it.
Park Royal
Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
So called capital of Suffolk, UK.
I agree with Milkybarkid. I bought, a so called 1.2m Orbital dish, it's height was 1.2m and only 1.1m wide. It did not pull in any of the fringe sats that my 1, Gibby does. Plugged all the holes and buried it in the ground for use as a shallow pond/bird bath. Slung a load of shingle round it, and in it, and planted some water plants in it.
Parky
geordiejohn
uk
big thanks for all the advice,went for the penta 85, just set it up this evening,still early days but channels like dubia sports on 26 east were very hard to lock on,rock solid now,well pleased!
satelliteman
Glad your up and running :)
Are we going to see any pictures in the 'pictures of members setup' section.
It's always a pleasure to look at the PENTA :D
guest poster
registered
Well done with 26e there (very well done- not easy that sat) .... where are you and have you got the MBC channels yet? (on 11919H 27500 on that sat).
geordiejohn
uk
I am in newcastle ,just east of the tyne bridge,tried mbc, auto and manual scan not a thing!might be better on a fine day.the penta seems to have a much tighter reception beam than the triax,i assume this is down to better build quality?
divibi
dvb-s pci card
85 cm offset dish
London
I would say so. The tighter the focal point the better the dish is. But correct me if I'm wrong or use wrong words for that.:)
guest poster
registered
Try inputting the data manually for all MBC channels first and use a tv.
Only after some real tweaking do we ever get MBC tp close to or higher than others... skew/ incline/ focal length etc..​
geordiejohn
uk
Nice clear day here,tried everything but no sign of MBC, been watching camel racing on dubia sports, very entertaining!
Reminds me a bit of when is was a nipper,getting up in the middle of the night to try and get north american medium wave radio stations.
satelliteman
Might you be just a little too North for mbC 11.919 possibly ???
