Its a satellite receiver according to the web specs of it. Freeview is a completely different transmission format, and your box is not suitable for Freeview.
My receiver shows in the front panel "DVB - Digital Video Broadcasting" and have a place in the back to connect the aerial. Because of this I'm assuming it works with digital broadcast but I'm not sure.
DVB applies to both satellite and terrestrial, but still both are different and use different tuners multiplexing and decoding. The aerial input at the back of the receiver is simply for looping through your terrestrial signal.
Thanks for your information. I'm using this satellite receiver for hispasat and think could use it for freeview at the same time... well i have to buy another receiver.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
