Goldwafer work with?
Genie
Make a wish
DM800 with 320GB HDD running Nabilosat 0.12
1 metre motorised dish. Intel core i7 920 PC
London
Do goldwafers, funcards etc work with all CI receivers or do you have to have a specially modified receiver/cam for them to work?
PRINCE
uh::
Most Receiver CI cam works with goldwafer, however some works better than others and some required an upgrade/patch before they works ,I suggest you search through the forum, you would find comments about how goldwafer friendly different receiver are.You want to avoid provider receiver though, as they have many in-built restriction.
Regards
Prince
