Good Hotbird Signal but No ART
Albhoy
Televes RSD 7254 receiver
Channel Master dish
Scotland
Be patient with me as I'm quite new to this.
I have set up my dish to pick up Hotbird and am get between 70 and 80% signal and mid 90's quality.
I can pick up in excess of 500 TV channels but no ART Sport
I've got the Al Jazeera Sport 1 and 2 showing o.k. (via)
Where am I going wrong, have I missed a setting?
I am using a Televes 7254 receiver. On it's Sat list it says Hotbird 1-5, will I have to perform a software update?
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
Your list is a bit out of date :)
Unzip this file and open with notepad, then enter the new transponder frequencies manually into your reciever (there'll be an option in your menus somewhere) then do a rescan of the satellite. That'll do it, no need to do a firmware change at all.
Any probs, post back.
And :-Welcome1 to the board mate :)
L.
Albhoy
Channel Master dish
Scotland
Thanks for the warm welcome!:)
I tried that list, thanks again, however still no ART.
I am seeing some more channels than I did previously but no ART.
Do you think it will be under a different name?
I am seing a test card for TKS1-7 or something?
Am I right in saying ART should be on 12015 H 27500 3/4, if so the receiver looks like it dips in signal and quality as it scans this part, however my allignment for Hotbird in general is great.
CONFUSED!!:confused
johnwilliam1
technomate 1500
strong 4375
pace digi box
triax 1.1, triax 88cm
UK.
it can be awkward to get, yes 12015 h 27500, concentrate on that frequency.
wod
yorkshire
just do a scan on that frequency
Albhoy
Channel Master dish
Scotland
Na! Still no joy.
I'll just keep on tinkering!
Lancelot
Retired Mod
SS1.
South central
Try a manual scan on just that transponder, and see if you can peak your antenna using that.
L.:)
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
What size dish are you using, as you may need at least a 80cm dish as Art Sports can be a bit of a pig to pick up.
Can you pick up Iqraa - Arabesque on 12.015H, 27500 which is also on the same transponder and is free to air.
If you can than you should be able to get Art Sports.
