GTMedia GTCombo 4:2:2 receiver
Offtensive
Midlands
The SF8008 can provide a picture of a 4:2:2 signal by routing the signal to IP as an mmu file or some similar type of extension. The kodi app in the SF8008 then connects internally to the mmu file and clears it.
Octagon provided a set of screenshots on the forum a while ago on how to do this.
Was the performance watchable on the octagon using that method?
Not tried it and unfortunately do not have an SF8008 directly to hand at the moment to give it a test.
There are a few members with the SF8008, hopefully one of them can test it out?
Manikm909
Small'ish Dish Man
Kent, UK
Installation via Telnet:
opkg install kodi-addon-pvr-vuplus
install pvr client
Start Kodi and enter the SF8008's IP address in the E2 client.
"scan tp 422, you have in the e2 ch list, start kodi, open pvr Client, they Show automaticly the ch list include 422 feed channels"
Have fun!
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
So, is the GT Media box better with 4.2.2 based on newer components inside...
Probably only a more powerful cpu, android boxes have been able to decode 4:2:2 for some time now, using certain media players, but only really low bitrates and mpeg 2 based files. They use the same technique as PCs, but the cpus are much inferior in speed. It was only a matter of time cpu's got quick enough to do h264 4:2:2. But I would guess they will only be useful up to a certain bitrate for now, so feeds that it is struggling with now, will always be a struggle.
Seems the main party trick of this box, is it can play 4:2:2 feeds 'live'.
I couldn't get it to work, but that was some time back..
I think that sums it up nicely :Y
It's the simplicity of it to give you a rudimentary view of 4:2:2 , BISS, and fairly inexpensive cost of the machine that is probably the attraction for a lot of people to acquire this machine - if development continues then hopefully it will go from strength to strength
Offtensive
Midlands
Try an online bandwidth calculator using 16APSK with a 33333 symbol rate, depending on the FEC over 100Mbps is possible..
Does anyone know how to workout the bottom 3 starred fields?
If you have the option to scan the frequency into EBS Pro it normally registers those parameters.
What satellite and frequency was the info taken from?
This just jogged my memory, back back in the day i used to use a Quali tv receiver for mpeg2 4:2:2 i think it was adequate
Yes, just a shame that the technology did not keep up to date my AZBox P+ was redundant for feeds at the end of the day I did have 4 years of very good feed hunting with it :D
I doubt GTMedia is fitting state of the art processors, moreso for the price the combo is selling for, but best of luck to those here receiving the first off the production line.
Perhaps somebody can pull the lid off both tuner cans and take some pictures for the forum.
rodscha
so basically it s the US color tv system? the old NTSC?
In what way is it interesting to receive it?
No. Imagine a 4x2 block of pixels. 4:2:0 means in the 4 pixels in the first row there are 2 with chroma (colour) information, the 4 pixels below on the next line have 0 colour information. 4:2:2 has an extra 2 pixels of colour information on the second row.
4:2:0 means on a 4K frame there are 3840x2160 pixels, each with luminance (brightness/black&white) information and 1920x1080 pixels of chrominance (colour) spread over the top. Standard 4:2:0 4K video only contains 1080p worth of colour! 1080p video contains 960x540 pixels of colour information.
A 4:2:2 4K frame would contain 1920x2160 pixels of colour - twice as much as a 4:2:0 frame.
4:2:0 video = quarter of pixels have colour information
4:2:2 video = half of pixels contain colour.
Manikm909
Small'ish Dish Man
Kent, UK
soooo sloooow tho
Manikm909
Small'ish Dish Man
Kent, UK
u know your shizzle mate
Not easy but here's a quick look. Not tuner cans as such, all on the pcb with a cover lid over the tuner section. Struggled to get the terrestrial tuner chip
That really is a badly placed heatsink.......
Carefully remove, clean off the old adhesive and glue back with good stuff (taking pictures of all surfaces as you progress :Y).
Manikm909
Small'ish Dish Man
Kent, UK
who would do that!
