- Jan 1, 2000
- Location
- North Nottinghamshire.
The cable came from the motor into my TM5402 box then using the loop out port into the Combo. I assume it's bad practice messing around with the coax cables whilst the box is on but i've done it hundreds of times without issue on other boxes. I was going to flash the box from my PC but to my disbelief amongst the myriad of cables I have I can't seem to locate a USB to USB and haven't had a chance to get one yet
>>The cable came from the motor into my TM5402 box then using the loop out port into the Combo. <<
The Combo's Terrestrial socket likes to give volts out of it but will be very unhappy to have a dose of 13/18volts fed into it's circuitry delivered from the TM5402's loop out socket. It could well be the end of it
