GTMedia GTCombo 4:2:2 receiver
pintu
gtmedia combo 4k . asiasat 5 100.5 e no computer
india
sorry 4.2.2 feed
Manikm909
Small'ish Dish Man
Kent, UK
new update out =- nice new UI
Only just downloaded it so not had any time to evaluate properly , which part of the UI do you mean ?
Also - anybody know where this 'Enthusiast' software file with the 'T' can be found
Manikm909
Small'ish Dish Man
Kent, UK
when you click ok, you now get a spectrum-scope kinda graphic for signal - nothing major, interesting about the T version. Must be on their site for download somewhere
the UI in general though to me seems a bit more polished,. it might be me, as i havent used it in a while.
maybe here
maybe here
Ok ta for that.
Iv'e had a look around the GTMedia site but didn't spot anything - i'll post the question on there.
Manikm909
Small'ish Dish Man
Kent, UK
Ok ta for that.
Nice "wan" JAES
maybe here
Really? All I get is the Siggy strength and quality as before? Maybe you have the enthusiast version?? Did you USB upgrade or OTA??
maybe here
Do you mean this display ? - if not i need some more clue's. :D.
The UI looks exactly the same as the previous version I had in..I take it you can change it in the menu somewhere??
Manikm909
Small'ish Dish Man
Kent, UK
thats what i meant mate
(i did online update- not USB
Ahh ok, i don't normally use that EPG option so i can't remember what it used to look like in the previous firmwares
Still intrigued about this mythical enthusiast version. I thought perhaps the USB one was it, but it's identical to the OTA version. Perhaps your mate Owen can enlighten us?
I've set the investigation off squire - awaiting reply's.
Online update 1.23 in (earlier was 1.20)
Like the move back from channel list to satellites, but IPTV logo is permanent next to names. Can I remove it ?
That is the GT Player logo if you are referring to the picture John posted earlier?
Manikm909
Small'ish Dish Man
Kent, UK
SimonE
Gloucestershire, UK
Guys, it may be me doing something wrong since the software update to 23. But when switching to SD pictures it displays two quarter size images top of the screen. HD pics seem OK.
Manikm909
Small'ish Dish Man
Kent, UK
thats a bug, reboot - or if persistent, do a system reset from the android menu (erases everything)
I don't have that issue here, some issues with recordings but I'm working through that.
