GTMedia GTCombo 4:2:2 receiver
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Ahh, reading that link has reminded me - i did use a usb mouse to get me back in busines but i can't remember the exact steps i took due to it being a long time ago
Don't you just plug a mouse in the usb port, then you get a pointer on screen?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Yep this did it though I still can't switch on from standby. I have to unplug and plug in again, only a new remote would fix this I guess But if the IR is broken from the box then it's a waste of money
Try the remote with your mobile phone camera, that should check whether emitting IR or not.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
How do you mean ?
Open your phone camera point the remote at it, press a button on the remote and you will see the IR emittor light up on the phone if it's working.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Open your phone camera point the remote at it, press a button on the remote and you will see the IR emitter light up on the phone if it's working.
Nope I don't so is this the receiver at fault or the remote ?
The remote. If you can get into the settings with the USB mouse, reset the box. Then as it sets up again after reset you should then be able to re-pair the remote to the receiver with Bluetooth. If not the remote I would say is u/s.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Oh as I said a few posts ago with a mouse I was able to repair the remote for bluetooth no problem without a reset. The only small issue now I can't turn on from standby but I can turn off ok
So the remote works then? Has something screwed up in the power setting menu, worth a look. You could also try a reflash of the software.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Oh no I'm not flashing any software. There were 4 updates from last year I installed a few weeks ago. The remote works now apart from the power button not turning on from stand by which is IR apparently, other functions are all bluetooth. Anyway i've bought another remote see is that works with IR
If you have a one for all remote, that may contain the power code until your new one arrives.
Manikm909
Small'ish Dish Man
Kent, UK
if you're gonna chuck it, then why not try updating firmware
statalite
SF8008
DiSEqC motor with 1m dish
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Throwing it would be sacrilege.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I just got the prompt to download firmware V1.28 (Dated 24th May)
Manikm909
Small'ish Dish Man
Kent, UK
yep me too
update oscam function
update disney+
update amazon prime
fix known bug (always a good one that!)
yep me too
update disney+
update amazon prime
Should read 'bugs' and plenty of them...
Apart from the audio lag/advance, mine has actually been very good over the two years, though I am not using it for much more than reception / steering a small dish.
I have found a reset within the menu clears most of the evils (5W 12548 V channel stuttering), and this latest update looks to have fixed that as well.
Awaiting an awkward 4:2:2 feed for some proper tests.
