GTMedia GTCombo 4:2:2 receiver
Joolz
1m Astro 55°E - 63°W
Unfortunately, my GT Combo also broke down last year, with no hope of being repaired.
I now have a V9 prime. It's not as sensitive with low-power carriers as the Combo.
of course it doesn't do 422 directly (although on the combo it was sometimes very unstable) otherwise it's a very decent receiver
where you can indicate the frequencies of 10490 (amateur radio on 26 East) which allows you to use a standard LNB, it can also read very small SR (sr300 is the limit that can be given with the original firmware). With Mars, it can go even lower (be careful, once the receiver is on Mars, it's very difficult to go back to zero).
Thank you for the useful information. For the cost I think I will give it a try.
Oh dear! an expensive weekend. It is most likely something like that that damaged mine.
So back to the question, what would I lose with a V9 Prime (£25) over a GT Combo (£85) apart from DVB T that I have never used??
If the V9 does not have a UHD/4K output, and you have a large screen and watch internet stuff through the one box it may restrict you.
Quite true. Another point is 4.2.2, the Combo produces a picture albeit juddery. The V9 won't.
s-band
Essex
Hmm, 2-4fps on some things 10fps if lucky and totally mangled if the aspect ratio is unusual
Miika
MM9800S, TBS5925
Estonia
Was that a guess ?
Analog output is totally independent with HDMI, because it is produced in processor before HDMI part. But as we know now, GT Combo sadly has no AV output.
But it has SPDIF output, so Joolz should try can this optical out make some sound.
Retired human
So it's like a very expensive radio...
s-band
Essex
I found this video from a 1080p 4:2:2 feed recorded a few weeks ago. It shows the frame rate achieved. The broken audio is typical.
  • output.mp4.zip
SimonE
Gloucestershire, UK
Still very pleased with my GT Media Combo but I wonder if anyone else has spotted a problem with BBC News HD. I am talking about the version that goes out to Europe on 19.2E or 26E for the Middle East. When I select it the output goes very light and edgy. Mine is working with its output set to1080i. Only when you select another channel does it go back to normal. Other receivers I have work perfectly normal. Something for you to try yourselves.
rodscha
several BBC News europe channels are in SD (hotbird)
a few are in HD (one on asra1)
itchybag
1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
earth
guess its relying on cpu for 422 decoding rather than the decidated silicone. Years ago i tried 422 on an nvidia shield. was a mess with anything over 12mbit
halliwell
galaxy
Ger
quick question!
How can I switch the Audio Track.
I lent my Combo and I do not know howto explain it from memory:-)
THX
SimonE
Gloucestershire, UK
quick question!
THX
Try pressing the blue key?
