Archive-8
What's the minimum Spec needed? To run pc "hacintosh"
https://www.tonymacx86.com/buyersguide/june/2017
Do these help ?
and then
Depends on what version of MacOS you want to run and budget.
I have had lion running on a dell optiplex 755, Yosemite on a vostro 200 and Sierra on a HP8200 elite.
Did you have any special requirements, as I have a dell optiplex380 I could use to possibly try it out.
I have an Nvidia gfx card that works out of the box for Macs if you want it?
Can't really add much else to what others have said already. You'll need patience and plenty of it. Watch YouTube videos, plenty of visual guides there too.
How much do you want for it?9800 gtx I think. Most recent-ish Nvidias will work. Avoid ATIs...
Just enough to cover postage... not going to ever use it for anything else.
well basically my motherboard is asus and my cpu is a amd athlon 2 x4 645 and im using yosemite zone which supports amd cpus and yosemite zone uses chameleonTry passing a debug flag on startup (I think it's a -d one - can't remember). What hardware (motherboard/CPU) are you using and what bootloader are you trying? There are several, like Chameleon, Multibeast etc.
Hackintosh is not for the faint of hearted - it took me many days to just install the thing.
