Hadu question
Tip Top
HTPC using DVBViewer
England
Hello, hope someone can answer this question...
I have a DM800 acting as a CCam server to my DVBViewer recording service. All clients are local to my home network - no internet c/s. I use hadu on my DVBViewer recording service to access my card server but everyonce in a while the picture on subscription channels pixellates or freezes, almost as if there is a poor signal, which there isn't. I dont have this problem on FTA channels. Does anyone have any tips for fixing this?
A common problem where there is a slow key update when the keys change.
Tip Top
England
Would the answer then be to have the DM800switched on and tuned to a pay channel then? Usually I have it in standby but never have any pixellation on the DM.
The only sure fire way is not to use cards sharing of any kind!
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
I had this setup when at home, worked very well! The problem could be with the DM800 settings as it might not be getting the key quick enough to share it or you could be using Wifi so Hadu isn't getting the key quick enough
Tip Top
England
Do you know what, I fully agree with you! The problem I have is that I want to use a HTPC as it gives me total flexibility and allows me to pipe TV all around my house using my PC network.
The pay operator I use however restricts use of their cards to their dedicated STBs only - if I could use a legal card and CAM I would be satisfied. Happy to pay a premium for that facility too. It's the "walled garden" approach that my pay TV operator uses that forces me into the DM + Hadu route. I'd far rather have a legal card and CAM that I could plug into my PC.
Tip Top
England
I've solved my own problem and thought I would share the solution. I had been using Hadu as a plugin on my DVBViewer Recording Service. By using the plugin on each local copy of DVBViewer instead I now have no more glitches.
