hfathollahi
- Jan 1, 2000
Dear M8
I tried to program a new titanium card for the first time with an INFINITY USB/PHOENIX programmer ( phoenix mode 3.58 Mhz) according to the following steps , but without success (also the software installed on XP windows) :
1- after connecting the programmer and running titaniumcardprogger 1.10 , it shows the card has OS 1.02 and mentioned ATR of the card . since it was a new card , I erased it
2- I reset the card
3-I loaded the necessary files for nagra encryption .
4- burned it .
5- during the burn process , titaniumcardprogger gave "writing failure" message
6- after that , the software mentioned :
| ATR : No ATR !
| unsupported Titanium OS found
and hanging on "sending TRAPCODE" .
I did different check :
-I tried several times for not hanging on the message "sending TRAPCODE" , but no success .
-Also I checked my pin to pin cable and the second port on my computer , but the result was same .then I tried on windows 98 instead of XP , again no success .
-Then I used older versions of the software and titaniumcard updater as well , still nothing .
-The problem still exists even when I make FIFO disabled .
******It always hangs on " sending TRAPCODE" *******************
I appreciate for any suggestions .
Do you know if my card is alive or dead .
behzad
2- I reset the card
4- burned it .
| ATR : No ATR !
behzad
