Hauppauge WinTV Nova HD S2 problem
hexah
Hadrians Wall
I have just bought a Hauppauge WinTV Nova HD S2 pc card.
I have tested it with a single LNB and a monoblock, with 5m of double screened cable straight through. It works fine on SD and HD.
However, DVB Dream and ProgDVB show the signal strength stuck on 100% and the signal quality stuck on 94%.
I have fiddled around for the last few days trying to find a cure.
:-comp
Today I moved the card to a different PCI slot then installed the latest drivers and Win TV7, which were released yesterday by Hauppauge.
No change.
Does anyone know if there is a cure for this problem?
Is it a hardware defect? :(
Don't know about your problem with those applications, but I find DVBViewer works flawlessly with my Nova HD S2 card. Best to get the Pro version though, well worth the small outlay for the extras over the vanilla version.
