Having a bit of trouble
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
I cant seem to find 7 deg e is there any tips you can give me. I get 13/19 28 ok and 30 w but 7 e is proving very hard.thanks:confused
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Sure there's not something in the way? Tree?
Are you checking the right transponder?
Check our Strongest transponer thread by searching the forum.
Where are you? Are you in the footprint?
frund
Wales. UK.
I hate to say this but ..I take my box with small tv into garden to setup dish [fixed on pole] the short sat cable I use had become loose but not disconnected [screw type plug] so no signal, I feel mega stupid. Thanks for your effort though.
BGonaSTICK
Brighton
No worries. We don't care, as long as your problem is solved :D
Yorks
Mentally unstable.
Pretend to know what I'm doing. Only the clever ones rumble me.
S. Yorks
Have you got it then m8. Only 12 mins left. Hope they score again for youO-Ha
