Help ! dm713s module
kgmra
Real Veiw MD 713s DVB-Card
COMP. :
Intel dul core 2
hd 1000 gb
jordan
Hi
i have a dvb-card some call REAL VIEW (dm 713s or dm 1105) or Index dm 713s
it only works with Progdvb 4.85.3 [1.38/Elecard Edition]
the modules files [DM1105.device , DM1105Cap.dll , DM1105IR.ini]
doesn't work with any other versions of Progdvb like 6 or 5
i need a new Module files
if anyone can help me i`ll be thankful
pleas HHHHEEELLP!
Mickha
North West
Have you checked the manufacturers website, if their is one, for any driver updates?
If you can't find any see if Windows has any updates drivers, depending on which Operating System you're using go to Windows Update and select the Custom option, you should then see some recommended driver updates.
wolfeye
G-Gurad
Hello Man
there you go here you can find the Module for Progdvb
_http://rapidshare.com/files/376937516/713S.rar.html
kanbelbel
opensuse 11 64 bit, kde, but gnome with vmplayer.
msi laptop: nvidia 8600, dualcore, 3Gb,320 Gb.
question: how to get a "/dev/video0" linked to my usb-dvb-s tv card?
Pakistan
I have this dm713s card too,i don't have the windows 7 driver, tried so hard and find the manufacturer,they have the link for the DM713S,DM714S Driver DVB-S TV Card Windows 7/XP/Vista _www.newmi.com
[Moderation] Unparsed URL
