help for Topfield 5000 CI !
edi
:mad: Can somebody help me for J-tag this receiver ?
I have only the J-tag cable. I want to have the Full Flash Dump for it and where to connect the J-tag cable to receiver (didn't get the place for connecting it to receiver )
If somebody can help or point any helpfull information will be great !
thank's to all !
here are the details
System ID 581
Loader L 1.12
Dev ver V5.0.46
Aplicat ver S-MSCI 5.04.90
wim6
TF5000CI
Dutch
You only have to use a rs232 cable to connect it to your computer and with the tfd downloader and the corret tfd file you can update your receiver!!
edi
thank's mate for your answer but I'm afraid my receiver Flash is dead, when I turn ON, I get 3 led's ON in same time,Orange,Green,Red. I'll try what YOU suggest,Yu're wellcome with another one if YOU have.
Thank's
