help me about password?
i enjoy using computer
us
hi everyone
I have a receiver DSN GR 6300.
I forget the password for it.
Is there anyway to reset it?
Is there any password work with it?
help me
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Welcome to the forum ahmedahmedahmed
I have to ask because I am curious why you would join a forum two and a half years ago and make your first post just now?
There is information about your stb available on the web however if it is patched then nobody would know the password apart from the patch makers. The unit is four years old
4000 Programmable Channels.
Fully Complaint with DVB-S and MPEG-2. Fully Complaint with DVB-S and MPEG-2.
Automatic Multi Reception (PAL/NTSC). Automatic Multi Reception (PAL / NTSC).
Cannel Edit : Delete, Move, Rename, Favorite Channel. Cannel Edit: Delete, Move, Rename, Favorite Channel.
DiSEqC 1.2 Positioner : Move, Sat Store, Realign Dish, Calibration. DiSEqC 1.2 Positioner: Move, Sat Store, Realign Dish, Calibration.
Up-grade Software by PC downloading (RS-232). Up-grade Software by PC downloading (RS-232).
13V/18V,22KHZ,0/12V Switching. 13V/18V, 22KHZ, 0/12V Switching.
Automatic Detection of Forward Error Correction. Automatic Detection of Forward Error Correction.
Satellite : 64 satellites, 120 transponder per 1 satellite. Satellite: 64 satellites, 120 transponder per 1 satellite.
LNB Power Short Circuit Protection. LNB Power Short Circuit Protection.
DiSEqC 1.0 & 1.2 Switching. DiSEqC 1.0 & 1.2 Switching.
High Sensitivity, Low Eb/No Tuner. High Sensitivity, Low Eb / No Tuner.
Powerful editing facilities : PIDs, TV or Radio Channels. Powerful editing facilities: PIDs, TV or Radio Channels.
TV Scart : select VIDEO and RGB, RF. TV Scart: select VIDEO and RGB, RF. Multi Audio Language. Multi Audio Language.
Multi OSD Languages : Engish,French,Greek,Italian,Russia,Polish,Arabic,Turkish,Albanian,…etc.
us
Can you give me the site for the company at the website?
Topper
No I cannot all I can say is it is Korean
as per Software & Hardware Form Korea
Which I assume to mean hardware and software from Korea
Buy an unsupported stb and you will have this sort of problem
I suggest you carry on searching google the way I did
