hamid200200
- Jul 7, 2004
- Age
- 45
i have starsat SR-X1500D Super MK-II satellate recivere and i want to upgrade it please instruct me how can i do it?
acmorfe said:i also have the same receiver. when i try to upgrade my unit the display changes to A001 briefly then shows E011. what went wrong? please help. thanks.
steps i took:
1. connect pc and receiver via null modem cable
2. put receiver on standby (clock on display)
3. run STB5518.exe (latest from satsw.com)
4. browse/select *.bin, press Start
5. display changes to A001 (briefly) then changes to E011
left it like this for 30 minutes, nothing happens...
DeepDiver said:I believe you should switch OFF and then ON again your receiver after you press START.
Hope it helps.
acmorfe said:help me, please....
or maybe tell me to get a hammer to smash my MKII and just get a better one -- a 200CI, perhaps?
but please say something...
thanks.
DeepDiver said:... make sure you get it with Model ID E224, and Hardware version 2.00
acmorfe said:Is there a way to know the Model ID and Hardware version without turning on the receiver? Written on the box somewhere?
Thanks for the reply.
Cheers!
steps i took:
acmorfe said:DeepDiver, thanks for the assistance. I think it was the fact that I was using a USB-to-serial interface. About 200CI+, is there a problem with H/W ver7.00?
DeepDiver said:No prob with h/w ver7.00, just when you go and download the update from satsw.com , make sure you get the 200CI_V7 file.
nadom said:i have the same reciver and i search for newer software for it but i don't find i'm sorry
