help me for star track 550d
sheritt
i need software & loader for this model
s/w vgd 3.0.4
h/w vgd 1.0
loader tp loader 1.0.1
thanks very much
Nels
The truth that this software is similar on Neosat 1600plus ??
tinu
junior member
star track 550d
uk
HI GUYS
I NEED HELP ON MY STAR TRACK 550D I CAN'T WACHT PORTUGUESE CHANELS OR CAHNELS WITH A SIGN OF $ AND IN SCREEN IS WRITEN 2SCRABLE TV OR SIGNAL"
CAN ANY ONE HELP ME AND I DON'T KNOW HOW TO UPDATE OR PUT KEY PLZZZ HELP ME
THANK YOU VERY VERY V EYR MUCH
MY EMAIL IS admin edit - email address removed
Tinu you are a flaming nuisance at the moment DONT post multiple copies of the same question around the forum. Have some patience.
Please follow our rules:
1 No multi posting of the same question.
2 No email address in posts - Forums work by the free and frank exchange of ideas, so any non personal information should be swapped between all members on the forum, NOT direct via email.
tinu
junior member
star track 550d
uk
i am sorry about that ... i am new at this usefull furum
can u help me plz
thks
Thats ok tinu - we were all new here once. Sorry I cant directly help - I dont bother with 30W, however, if you do a search for your receiver make and model on the search button up towards the top of the forum you will probably find loads of info about the receiver. You need to "patch" your receiver with whatever is the most recent patch for it (assuming there is recent software).
Forget the Spanish stuff for now, its gone for the time being.
tinu
junior member
star track 550d
uk
thanks anologuest
aiduenu
Dear guys am using star track 550d and am finding very difficult to use the code 9339 i read from this site that you can just enter the code 9339 and it will permit you but my star tracking is not allowing me to enter the 9339 it take only 2 digit th
Ghana
Dear guys am using star track 550d and am finding very difficult to use the code 9339 i read from this site that you can just enter the code 9339 and it will permit you but my star tracking is not allowing me to enter the 9339 it take only 2 digit then it tells me that no such channel?
