Help needed for startrack SR-X 1050
ssalah75
startrack SR-X-1050
windows XP
I have startrack RS-X-1050 receiver, I used to be able to update the keys manually from the remote by pressing menu then type 1117, yesterday I've upgraded to the latest software (28 sep) and after that I wasn't able to key in the keys using the remote. any one can help me in that.
Thanks​
ssalah75
startrack SR-X-1050
windows XP
I kept looking for a way to enter the codes from the remote,
and I want to share it with u guys,
press menu
then type 1118
and the codes menu will appear.
HerveKuwait
startrack 1050
Kuwait
thanks .
it works with 1118 .
do you where to find the keys for showtime and how do you enter the IRDETO keys when there are 16 pairs instead of 8 pairs ?
THANKS
