Satellites221
- Apr 25, 2018
Here is a link to the cahors one (100cm):
or the gibertini SE professional 100cm.
Price not issue similar prices. Which is best is there a easy way to protect the nuts and pieces against rust, are they likley to last and perform the same 10 years down.
I heard a lot about channel master but I don’t want the hassle and I only have just received permission for 1M with post inspection.
which would you likely pick and why?
Any advice is helpful, thank you.
Fibreglass Universal Satellite Dish | Free-to-air, Astra, Hotbird, Saorsat100 cm / Dish Only
See our wide range of dishes LNB's, Wall Brackets, and installation kits. We provide everything you need for a Satellite System. We provide everything you need to set up this system yourself. Low Cost and Fast Shipping to Europe and the UK!
www.tekeir.com
