johnh25
- Aug 31, 2009
- Age
- 41
- Not sure yet, need advice from experts!
- Liverpool, UK
Good afternoon folks,
Please bear with me as I have very limited knowledge in this area of expertise unlike you lot!
I work on a ship in the North Sea (off the coast of Aberdeen).
We have a dish with a quattro LNB feeding a multiswitch (triax tm5x8).
I want to add extra user outputs but this particular multiswitch doesn't have loopthrough of the inputs so I need to do this another way.
I found these things;
It is a tap out. I don't quite know what this thing does, I was assuming that you place it before the multiswitch and then this allows you to add an extra multiswitch from the extra outputs on the tap? is this correct?
Does this thing also boost the signal?
Thankyou very much in advance for any help
