kingcross
- Oct 8, 2005
- Age
- 45
- cable
- USA
i am trying to setup a reciever in Africa, and i am looking forward to buy PANSAT 3500SD FTA reciever. So, i am not sure if the reciever frequency will be suitable for the West Africa frequency(NIgeria). Please, can someone tell me if it is possible to use it in Africa...bellow are the features:
Pansat 3500SD Features
EPG (Electronic Program Guide)
Full Compliant of MPEG-2 Digital & DVB broadcasting
950-2,150 MHz input Frequency (IF Loop Throughout)
Variable Input Symbol Rate (1-45 Msps)
Multi Language OSD
Automatic PAL/NTSC Conversion
Fast Channel Change
5,000 Channels TV & Radio Program
Universal Remote
Flexible reception of SCPC & MCPC from C/Ku-Band Satellites
S/PDIF (Digital Audio or Dolby AC3 Stream out)
Timer Function (Automatic Turn On/Off by Setting Function)
256 Colors (Graphic User Interface) Number
PIG (Picture In Graphic)
5 Favorite List & Unlimited Programs per each
Powerful Channel Editing Function
- Sorting : Alphabetic, Satellite, FTA/Scramble, Parental Lock
- Move, Delete, Favorite Edit
- Parental Lock, Channel Rename, Channel Skip
Manual PID / Satellite & TP / Network Scan
Smart Search
Satellite Scan – Simultaneous Scan with 4 Satellites
DiSEqC 1.3 Control Compatible (STAB USALS)
Capable of Setting the Frequency for SMATV System
Software Upgrade via RS-232C (Receiver to Receiver, PC to Receiver)
1.2 Additional Features
Component Out (YPbPr)
RTC (Real Time Clock)
1.3 Conditional Access
Conax CA-7 Embedded
1.4 Secure Digital(SD) Card Access
MP3 Audio file decoding
Firmware Download via SD-Card
- Easy software upgrading
Specifications
Embedded smart card slot
1 Smart Card Reader(Conax)
SD-CARD Interface
1 SD-Card compatible memory card slot
Front-End
2 Input Connector F-type, IEC 169-24
IF Input Frequency 950MHz TO 2150MHz
IF Loop throughout 950MHz TO 2150MHz
IF Frequency Zero-IF
Input Level -65 dBm~ -25dBm
LNB Power 13/18VDC / 500mA Max
DiSEqC Control Version 1.3 Compatible
Band Switching 22KHz Tone
Demodulation QPSK
System Rate 1~45 Msps (SCPC, MCPC)
Viterbi Decoding Rate 1/2, 2/3, 3/4, 5/6, 7/8
Reed Solomon Decoding FEC: 204, 188. t=8
DiSEqC 1.3 Compatible (STAB USALS)
MPEG Transport Stream & A/V Decoding
Demultiplex According to ISO/IEC 13818-1
Input Stream Max. 90Mbit/s
Aspect Ratio 4:3, 16:9
Video Resolution 720 x 576(PAL),720 x 480 (NTSC)
Audio Decoding MPEG layer l and ll
Audio Mode Single/Dual Channel, Stereo, Joint Stereo
Audio Sampling Frequency 16/22,05/24/32/44,1 48khz
Microprocessor & Memories
Main Processor STi 5518 DVB, ST20 32 bit
CPU Clock 81MHz(100 MIPS)
Flash Memory 2 Mbyte
SDRAM 16 Mbyte
EEPROM 32 kbit
Data Port
Connector 9 Pin D-Sub Type
Protocol RS232 Asynchronous
Data Rate Max. 19,2kbps
RF Modulator
Connector IEC 169-24 Male / Female
Frequency CH 3 (61.25MHz) CH4 (67.25 MHz)
Output Channel CH 3-4
TV Standard NTSC
Preset Channel CH3, Changeable by Menu Screen or Manual Switch
Front Panel
4 Digits LED Display Channel Number Display
8 Keys Power, Channel Up/Down, Volume Up/Down, OK,
Exit, Menu
Rear Panel
IF Input F-type Connector
IF Loopthrough output F-type Connector
6 Phone (Cinch) Video, Audio L, Audio R, YPbPr
S/PDIF Optical AC3 Audio Out( to Digital Input Audio Receiver)
Skew 3 Push Terminal (5V, GND, PULSE)
S-VHS
UHF
Modulator
RS232 Serial Port 9 Pin D-sub Type
Y/Pb/Pr Digital Component Video Out
Remote Control
Type Infra-red (Carrier Freq : 38 KHz), Universal
Battery 2 x 1.5V AAA Type
Electrical and Mechanical
Input Voltage AC90-250, 50/60Hz
Power Consumption Max. 55 Watts
Standby Power Less than 5 Watts
Dimension 290 x 200 x 65 mm,2.1 kgs
In future post only once, no need to double post and don't hi-jack someone else's thread.
Multi Language OSD
Fast Channel Change
Universal Remote
Smart Search
Conax CA-7 Embedded
Specifications
SD-CARD Interface
Front-End
Demodulation QPSK
SDRAM 16 Mbyte
EEPROM 32 kbit
Data Port
RF Modulator
TV Standard NTSC
Front Panel
Exit, Menu
Rear Panel
S-VHS
UHF
Modulator
Remote Control
