Help unscrambling Channels
amman
amman
Tehnosat 9800P Omega DICP
2CI
jordan
Hi there,
Hve a technosat 9800p omega dicp.Installed latest software and software for keys(R3c... file)
Hispasat @30W and Hotbird@13E hve been successfully unscramblled/working except for TV Cabo software which is currently not available.
My question is :
hve the following sats : Astra1/Astra2A/Sirus 2 with lots of scramblled channels that should open since most of them are the same found in hispasat and Hotbird.
Are there key softwares for them that can be obtained /downloaded into the receiver to unscrambell them.
In the affirmative, wud appreciate yr advice as where these files can be found on the web.
TIA
amman
amman said:
Hi there,
My question is :
TIA
amman
No - different encryption systems. Anything scrambled at 28E (Astra 2) is totally secure.
19E - Astra 1 some is open with a dragon cam. Premiere only with a particular type of card.
Sirius - some of the Cryptoworks feeds are currently available.
Files / keys can be found on the usual file sites - there are thousands of them around!
amman
amman
2CI
jordan
Many thks yr reply.
Astra 2a : noted
Astra 1/19E: any available keys files to download into receiver instead of cards/Cams.
Sirus- Wud appreciate yr clarification>
Re files/Keys cud u pls list some sites/locations if it is permissible.
Best regds
