Help Wit Titauim Card
kenny
Ca someone help me with a problem. I have a infinty usb phoenix and a tit card the problem is i cant get it program for me . The question is what setting do i put infinty in and what files for the card thanks Kenny.
You need to use the phoenix mode in the Infinity software, then download and open the latest version of Titanium Progger, you'll find it in the utilities section. Don't forget to erase the card first with the Titanium Progger. You need to go to somewhere like www.fookfiles.com to get the files.
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
I had the same prob with the infinity as it doesn't recognise the OS and won't erase the card. The elvis is as sweet as a nut. I need to work on the infinity a bit more to find out why.
The only problems I had with the infinity were firstly failing to read the manual, so didn't realise that I needed a serial connection as well :) and secondly that I needed to turn of FIFO buffering on the COM port, otherwise it was great.
jimbo
Retired Mod
Greater London
Bit of a misnoma is 'Phoenix USB' I'd say....... since the phoenix element needs a serial port and lead.
Mind you I am a bit of a cynic. :rolleyes:
