Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite Tv Encryption Decryption
Encryption Systems
Viaccess
help, with sic international channel at 16*0E Eutelsat
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="driver" data-source="post: 555130" data-attributes="member: 295515"><p>hi m8</p><p>i had once a similar problem</p><p>the answer was in the dish set up .</p><p>check you have got correct setting for lnb type.</p><p></p><p>9750/10600.</p><p>there is another similar but incorrect setting.</p><p></p><p>you dont say what message your box gives.</p><p></p><p>if it says "no audio/video"but the prog information shows,then you are not patched to recieve it.</p><p>if it says no signal.</p><p>then you have a set up problem,in the dish/lnb/tuning area.<img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="driver, post: 555130, member: 295515"] hi m8 i had once a similar problem the answer was in the dish set up . check you have got correct setting for lnb type. 9750/10600. there is another similar but incorrect setting. you dont say what message your box gives. if it says "no audio/video"but the prog information shows,then you are not patched to recieve it. if it says no signal. then you have a set up problem,in the dish/lnb/tuning area.:) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Encryption Systems
Viaccess
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
