Hex file for Star-Sat Receiver?
Alexy
Dear Friends,
Where can I find the newest hex file for star-sat receiver?
Alexy
I found some hex files, But I don't know that I can use them for STAR receiver or not(?).( There was not written that which receiver can use this hex file )
Do all receivers have special hex files, or I can use for example 1 hex file for 2 different kind of receivers?
Please help me!
earth
each receiver has own hex let me know which starsat then w'll send it to u
Alexy
Dear earth,
Mine is SR-X150D PLUS . I found it's hex file in satsw.com but it's not the latest one. I want the one which can open for eample calcio tv.
I would be appreciated if u send me the new hex file.
thx
earth
sorry no news about it now,but when i'll have ,u'll be the first
amerkhalilus
Hi there,
I have downloaded a file SR-X3200cu from satsw.com but when I run the file to download to the receiver it gives a warning "Waiting BOOB" and when u click ok on it the download doesnt start.
Can you please help.
Amer.
ghods said:
I have & use this file & it's ok.
if you still want it , send me your email .
my e-mail : ghods2004@yahoo.com
mo1965
Hex keys are the same for all recivers and cam and cards. software emulators are different for each receiver.
I think hex are not allowed in this forum but you can check this website for them:
www.rdi-sat.com
The software you get from satsw.com normally has the hex eprom with it and program to use which is different from the one you use to upgrade the receiver which is either Emedit or Emupgrade
haleti
Anyone would like to share the information on STAR SAT SR-X650 ci Super how to enter the codes via remote control and where to get the codes such as : Iredeto , Nagra and so on.
don be afraid to share the info .. or advise where to find out more on that.
Also is there any Tool software .. for editing the menu in the receiver ??
waiting for experts reply.
ciao.
f1167
need patch emu for starsat SR-X1500D_SUPER_MK_II
if any one can help
thanks
moemaita
amerkhalilus said:
Hi there,
Amer.
ive got the same problem that you have in that"waiting boob" did u find a solution for it. if so could u tell me how?!! thanX :D
hamid_0631
hello all.
1- where is HEX key in internet for downloading (zip file) or a good and simply SITE?
2- wath is the way of connect for pc & reciver ? (in ZIP FILE or PDF)
3- wiche programs is the best ?
TANK U to NEXT.
hamid_0631
hello all.
TANK U to NEXT.
A-AGRIC1383
Dear Friends,
Where can I find the newest hex file & Codes for star-sat receiver (model : sr-x750ci) ?
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
not a problem!
glad to be of service.
please come back soon!
harrypotter
Hi please help me.
for programming my receiver (starsat X-200CI) i did:
1.Went to www.satsw.com.
2.Downloaded item number #11 which is loader(emupgrade)
for starsat and installed in my pc.
3.connect nine pin female+female(rs232c cable) for
connection between pc and receiver
3.Started the loader(emupgrade) and browse for bin file
sr-x200ci (I downloaded this file from www.satsw.com).
4.Checked my current model I.D, h/w version, s/w version
from STB status of my receiver and compared with the
laoded file on emupgrade.
5.my current model (receiver) is h/w ver=2.00 , s/w
ver=2.55 , model I.D=E224 and for sr-x200ci file was hw
ver=7.00 ,s/w ver=2.64 .model id=E224 ??? (after E244
was 3 question mark) therfore I pressed start button
of emupgrade for downloading.
6.Powered off my receiver from backside and restart
again.
but nothing happened !! what is wrong??
(maybe I should say peressing 1234 I
entered STB setting and I deleted all
viaccess codes manually)
please answer me what should I do step by step.
Have a nice time.
thanks a lot
ngeorge
Is your cable Null Modem. Means the connection should be 2-3, 3-2, 5-5. Check on Google how to make null modem cable. 2nd thing choose correct com port. 3rd correct software from www.satsw.com. If all ok for sure it will work.
