Hi ,New Need Help Bad !
Satimpaired
ariva 18x24 3 dual lnb dish ,
2 sonicview 8000hd s
Canada
Hi ,I am new here and frustrated . I hope someone will take the time to help out .
I have 1 Dish with 3 dual LNBs ,2 4to1 EMP Disecs , and I would like to hook it up to 2 receivers . Do I go from 1 side of the LNB to each separate Disec ,then 2 cables -1 to each receiver ?
Thanks to anyone for any Help !
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
If I've understood your explanation then the answer is basically 'yes'.
From LNB 1, cable 1 to say Port 1 of Diseqc Switch 1; cable 2 to say Port 1 of Diseqc Switch 2.
Repeat for remaining 2 LNBs i.e. LNB 2 cables to say port 2 of each Switch; and LNB 3 cables to say Port 3 of each Switch.
Then one cable from each Switch to each Receiver.
Job done, get beer, watch TV!
Satimpaired
Canada
Yep ! You have understood ! Thank You for clearing that up ! Appreciate it , You deserve a beer for that !
