Horizon HDSM USB - Latest Firmware and software
makidoja
Installer
Cambridgeshire
Hi I have a HDSM USB V3 can someone help me. I need a updated Sat List for UK
I just need the following beams
Sky-Q P1 28.2E (H)
Sky-Q P2 28.2E (V)
Astra-2E - 28.2E (H)
Astra-2E - 28.2E (V)
Astra-2F - 28.2E (H)
Astra-2F - 28.2E (V)
many thanks
See link
Link to Software & UK Sky June 2023
jaimauk
Sky tv
Scotland
thank you very much
coinhas
Hispasat
Jersey
so yeah buddy windows 7 i have the list ready now i need your contact to connect on whatsapp. How can you send me a private message with your phone number.
Hi Peyu75, woul you be so kind to sort out a sat list like you did for Windows 7. My Horizon is a V3 USB HDSM. I would really appreciate your help bud. Thanks in advance
danfat
Hi there, i Have a of Horizon V3 USB HDSM that isn't working. could you help me with the software please?
inocv
HDSM USB PLUS
karlovac,croatia
hello, I am new here, can anyone help me, i need horizon V3USB hdsm software for Astra 19,2, Eutelsat 16A at 16,and Hot Bird 13, the latest version is HDSM USB PLUS 1.0Ba-0045 thanks
paulgrut
Commercial Installer just starting to tinker with FTA in the US.
USA
Hellomarkalmond
I will help you in the middle of next week.
What other satellites do you want besides 30w.
Please send me a private message with your phone number, I will connect via whatsapp.
Regards
Peyu75-
I am very familiar with creating .pat files and .lst files with SatEdit1-23 for the HDSM meters. Is there a SatEdit software (or hex loader) that
works with the HD-S2 and HD-S2A meters?
I have seen reference and screenshots of S2_SatEdit.exe
I would like to be able to load my existing .hex files in the HD-S2A meter.
Thanks for any help,
Paul
paulgrut
USA
hello,
where can i find the S2_SatEdit Program?? What is this "PW" you talk of?? it would be nice if you provide a link to download the tool via MEGA or googledrive or whatever.
thank you!
best wishes
Dc2ni-
Did you ever find the S2_SatEdit Program? I am also looking for a way to update lists in my HD-S2, like I can in my HDSM Meter.
Thanks for any information.
Paul
Peyu75
Prodelin 3,7m astra 28.e. UK zone
Dish 2m 90E-43W Heavy Duty 36
Poland
Colleagues, the program for making and uploading lists to the S2 model has never been made publicly available by the company. It cannot be found online. I have it because I made letters for horizon. When working with it, be careful not to damage the meter's software. That's why I connect to everyone I help with this program via watsapp and explain what needs to be done. Regarding the USB model, I also have the same program for it as above, colleagues attached in the posts. I do not write letters to him because it is very time consuming. Regards.
coinhas
Hispasat
Jersey
Hi Peyu75 , could you private message me please because I can't message you.
tubakias1
HOTBIRD
GREECE
Good morning ...
Since the site is closed I am from Greece and I would like the latest satellite upgrade for the Discontinued model HDSM v2.50
thanks ........... GR315051.....
marcel_uk
satellite installer and dreambox fun
  • Firmware-HDSMUSBupdate0045.zip
  • HDSM SatEdit v1-23.pdf
  • HDSM_uk-sep-2021_UK.zip
  • hiew32demo.zip
  • SatEdit HDSM 1-23 User.zip
  • SATS.zip
Dc2ni
Schwaiger 80cm Nokia dbox 2
Germany
I hope someone can help this.
I have Horizon HDSM USB when i switch on it says axcess current and then it goes off.
i have replaced the battery but no look. anyone come across this?
Hi
Can you explain it more detailed. What exactly is written on the display? I guess it says exceed current … which I think is because of a short circuit in the signal input terminals (f-connectors) or somewhere else in your meter.
Please check everything for any short circuits.
If you need any more help just contact me.
Dc2ni
Germany
Hello
I now writing this the third time , due to some complications (after reply without log in and login afterwards, the reply was deleted… then second reply was deleted due to phone Akku was depleted… )… so again:
Hello
I guess the meter said exceed current. So please check your meter for any short circuits inside or at the signal input terminals / f-connectors or at the battery you have changed recently.
If you need anymore help, just feel free to ask.
Best wishes
DC2NI
Dc2ni
Germany
Hi thanks for the sat list. I have a Horizin HDSM USB Meter and it has a new battery . but once the meter is showing 93% battery it shuts off and then i have to recharge the battery even though it shows 93% still in the battery .
Why is this would you know?
Hi
I guess the battery has some faulty cells inside or a massive disbalance.
So look with a multimeter for disbalance between the cells or for dead cells.
Contact me if you need more help.
Dc2ni
Germany
Hi
I have HDSM USB, it does not turn on while i have replace new battery. only it gives broken beep when put on charge. it was okay when last used around a year ago. Can any body help me in this regard,
Thansk
Measure up your cells inside the battery pack if the cells are ok. And look for disbalance.
Each cell should be at the same level as the other cells and between 3.7v and max 4.2v
All in all the battery should provide the voltage labeled outside 14.8v
If any help is needed contact me.
Dc2ni
Germany
Discharge the battery by hand outside till each cell is at about 3.7v or all in all voltage is at about at 12v.
Then reconnect the battery as labeled! First connect 2pin connector the the 4pin connector.
On disconnect last disconnect the 2 pin connector!
stelmosfire
Sky Dish with Horizon meter
Scotland
I have an old Horizon NanoSAT that doesn't contain the latest Astra Satellites.
What I am unclear on is because the satellite position is the same, 28.2e, does it matter that the name of the satellite has changed from Astra 2D to E/F/G will it still lock on? My testing didn't seem to show this and assumed I need to update it.
The update file is attached, from what I can tell they never released an update over the lifetime of the device.
Is it going to need the usual HEX file edit? Anyone know how?
  • NanoSat UK default.zip
