Horizon HDSM USB - Latest Firmware and software
Yes, I understand.
I posted the same information previously.
I just wondered if anyone knew of a 28.2E H-H DVB-S Tx that wasn't listed or common knowledge.
I might back up my STB's install info, do a blind scan and report back if there's any positive result.
I'm just trying to push out the time when my Horizon V3 USB DSM will be relegated to a rather expensive door-stop!
There arent any - even the feeds up around 12500-12700 tend to be DVB-S2 these days.
EJK65
Astra2, Astra1 & Hotbird with 4 into 1 DiSEqC switch. Win 10 PC.
Co. Kerry, Ireland
Hi All,
I'm not sure if I'm posting this in the correct post...!
But, I'm looking to replace my HDSM V3 USB as it's becoming obsolete, as discussed previously.
Would anyone have experience with the GTMEDIA V8 DVB-S2/S2X Signal Finder (with 3.5" LCD)?
They're available on ebay from €55 upwards.
I did have the GTMedia GTC Android Combi box before. It was a bit of a pain to setup and I wasn't impressed with their s/w updates to fix obvious functional issues.
Or maybe someone could recommend some other low-cost S2 sat meters, as I can't justify spending too much!
I'd appreciate any useful feedback.
Many thanks in advance.
Hi All,
Ive got a similar but much older version of that branded Dymeco. Utterly useless on any day with the merest hint of sun as the screen is totally unreadable. Ive given up on mine & gone back to an old satellite receiver with a small tv
satellite2
Horizon HD usb
Ireland
Hi City Aerials looking for uk list for usb plus if available ? Thanks in advance Pilsner
Hi there, I'm looking for the usb plus transponder list. If you have it please.
ogi101
humax
uk
Hi, can we load the transponder list onto HDSM USB/Plus using SatEdit if it is in .hex format? Or does it have to be .lst thank you
ogi101
humax
uk
Hi, does anyone have pat files for 28.2 (for Horizon USB/PLUS meter)? Thanks in advance.
hifial
VU+
I also would be grateful for an updated list for 28.2 both legacy V & H (Hi & low) and SkyQ Thanks
damodamo
freesat installer
ireland
hi i was in same problem with my horizon meter i could not get softwear so i just made a custon carrier and it works try this you can put it in on meter no fuss iput in 11307 h 27500 23 for freesat astra
