Horizon HDSM USB - Latest Firmware and software
simat
SIMAT
SPAIN
buenas tardes les escribo desde gandia españa, tengo desde hace tiempo el modelo HDSM v2.50 y tengo los satelites cargados
Astra-1-19.2E(H)
Astra-1 - 19.2E (V)
Hotbird 13E (H)
Hotbird 13E (V) que son los que usé, pero han llegado refugiados ucranianos al pueblo y quería poder dirija la antena tambien a
Astra-4A - 4.8E(H)
Astra-4A - 4.8E (V)
Astra4AN4.8E(H)
Astra4A N 4.8E (V) Me podria
pasar el archivo con los satelites que tenia y los ¿Quiero?
Gracias
disculpe mi ingles yo uso traductor
Mod note: please also post the english translation :)
Good afternoon, I am writing to you from Gandia, Spain. I have had the HDSM v2.50 model for a long time and I have the satellites loaded.
Astra-1-19.2E(H)
Astra-1 - 19.2E (V)
Hotbird 13E (H)
Hotbird 13E (V) which are the ones I used, but Ukrainian refugees have arrived in the town and I wanted to be able to direct the antenna also to
Astra-4A - 4.8E(H)
Astra-4A - 4.8E (V)
Astra4AN4.8E(H)
Astra4A N 4.8E (V) I could
pass the file with the satellites that I had and the Do I want?
Excuse my English, I use a translator
simat
SIMAT
SPAIN
Excuse me, to load the list, do you need a special program? If so, I would also appreciate it if you would send it to me
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
Horizon decided to use a rather stupid way to upgrade the settings list, as has already been explained: you go to their website, select the satellites you want to use and the website then generates an executable program, which you download and run on your computer with the meter attached. This custom program will then update the selected satellites.
Since Horizon closed down, so did the website, which is why nobody can now upgrade their settings, unless somebody programs a suitable settings editor. I don't think that such an editor exists.
And I wonder if it makes sense to invest a lot of time in developing a settings editor for Horizon meters, since they are basically obsolete.
What people have been doing in this thread, as I understood it, is exchanging their last generated settings executables.
Peyu75
Pace MSP980 Positioner x2szt
GI-S 980 2CR2CI HD PVR
Shovboxvitamin 5000HD
Lnb single Invacom SNF-031
Dish 2me 90E-43W Heavy Duty 36"
Orbitron mesh 3m
Laminas 1,8m 28E {1N 2F}
Poland
hello I have a program for making lists for the USB model and hd s2, if anyone is interested, please visit PW. sorry for the language I am writing from the translator.
@simat what transponders do you need I will make you a list of which satellites with tp should be included in PW.
Peyu75
Orbitron mesh 3m
Poland
F0DD7D60-CEC2-482D-ABF5-F801959A4006.jpegA0DE999A-1332-422F-AC16-B5E8D9EBFAA1.jpegB1568C64-48D7-4C32-8A7E-4A269E22F3EA.jpeghere is the program for the USB model and for the s2 model, I myself edit and make my lists. And the letters that were from Poland on the server were my work.
  • SatEdit HDSM User Guide.pdf
CrazyRadio
any
uk
Hi just joined the forum, does anyone know where i could find the latest firmware with the latests Astra 28.2°E & Astra 19.2°E my meter is V3 Plus not sure if the different versions are compatible.
rasheedjalib1
nill
mancheter
Hi
I have HDSM USB, it does not turn on while i have replace new battery. only it gives broken beep when put on charge. it was okay when last used around a year ago. Can any body help me in this regard,
Thansk
cityaerials
Installer with horizon meter support
Coventry
Hi i would be interested in software creating lists for the HD-S2. Many thanks.
cityaerials
Coventry
cityaerials
Coventry
Astra-1-19.2E(H)
Astra-1 - 19.2E (V)
Hotbird 13E (H)
Astra-4A - 4.8E(H)
Astra-4A - 4.8E (V)
Astra4AN4.8E(H)
Gracias
Astra-1-19.2E(H)
Astra-1 - 19.2E (V)
Hotbird 13E (H)
Astra-4A - 4.8E(H)
Astra-4A - 4.8E (V)
Astra4AN4.8E(H)
Hi, Try this for now, I will try and sort some A4a tps out.
  • simat-HDSM.rar
cityaerials
Coventry
  • crazy-radio- HDSM.rar
  • Firmware-HDSMPlusupdate0045.zip
CrazyRadio
any
uk
hi try these.
Hi i just tried uploading the HDSMPlusupdate0045 but it stated already updated strange, so i loaded the crazy-radio.hex list and that did uploaded i can see SkyQ, but i also tried the Firmware-HDSMPlusupdate0045 and that loaded fine as well now I'm spoilt for choice thanks.
Are these lists updated on here quite interested, great site by the way
Peyu75
Orbitron mesh 3m
Poland
there is a program that shows above it is easy but very time consuming
ifibra
World
Limassol
Hello Mate, where is this PW? can you send us a link please?
CrazyRadio
any
uk
Has anyone found the program to make or edit the HEX files, thanks
