Horrible video quality NoK 9500+DVB Help
B
b7
I have just bought a 9500 with DVB200 V 1826 installed.
The picture on any channel is awful, like a pop video when they go into negative effects with colour, or a jpeg that is too compressed.
LNB works fine on my analogue Receiver and it is a Universal ( cambridge )
9500 will scan astore channels etc. OK
Have carried out a reset by holding up down buttons and bringing out of standby as suggested by someone on another forum, but no different
Any ideas?
w hole
uk
Hello B7
How are you connected to to TV. [RF or Scart]
It could be that you are set up for RGB, which can look a bit odd if the TV isn't re-adjusted for it. [Not all can be]
Check the video output settings on the Receiver and see if is set to RGB, and if so try changing it.
Just a thought!!
Good luck
W Hole
B
b7
I have the 9500 connected direct to TV via a fully wired scart connection which auto switches to the 9500 ouput when I switch on the receiver.
Have also tried a small colour portable with scart and the effect is similar.
Swapped the scart as well....Grrrrr ..... frustrating :(
Thanks for reply.
