viccos
- Dec 7, 2008
- Age
- 59
1 dish on hispasat 30W
1 dish on astra 13E
sky HD+ , tv cabo ,2 tecnomate 1500+
- carshalton surrey
hi guys, i need some info about the Humax foxstar HDR, Can i connect 2 sat. (astra2 + hispasat ) on the humax HDR ? I was thinking this way; 2 cables from astra dish, and on 1 of those cables i could fit a diseq switch so i can connect the cable from the hispasat dish.so will be 1 cable direct to the unit and the other 2 via a diseq switch, is it possible ? will this set up work ?
Another question; freesat receivers, they are normal receivers aren't they? i can set it up on any satellite or not ?
thanks for your help guys.
