How do i get into Pre*miere Sport Portal (EMERGENCY)
milo2006
HUMAX HDCI-2000- Triax 100 cm Dish
S/W: HDMXSCI 1.00.15
System ID: 3002.0000
Loader: U 4.01
Diablo CAM Stealth241/Dragon T-Rex Predator366/CAS2 Plus programmer
Helsinki
Hi Guys;
I have HUMAX HDCI2000. I was in Pre*miere Sport portal and pressed the yellow button which brings a table for satellites, nothing like you said. I am missing the game barcelona v celtic and i am very pissed.
Most of the Pre*miere Direkt showed the other games. Two of the Pre*miere Direkt had black screen. Only Pre*miere Sport 1 which was showing about 5 min from each game and I did not enjoy it so much.
SO CAN SOMEONE HELP ME STEP BY STEP HOW TO GET THE CHANNELS FROM THE PREMIERE SPORT PORTAL?
I will appreciate it a lot
Thank you
Milo
See the previous post in this section.
I'm watching two matches showing now on Sport Portals 1 &2, Celtic match on Portal 2 at 12:15 local time.
milo2006
Loader: U 4.01
Helsinki
Which previous post? If you have the same receiver, why just tell me what you did exactly? I am tired of looking since yesterday in different forum and got many responses but none of them helped me because they all have different receivers.
Thank you
M
milo2006
Loader: U 4.01
Helsinki
Three on the Laural's list and the same on the fixed dish list I made, which is my modification of Laural's motorised one.
milo2006
Loader: U 4.01
Helsinki
Why don't you just answer my question, you are giving me a bit of hard time! I just asked a simple question about the number of channels in the Premiere Sport Portal and you answered differently.
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
You can try searching manually (without using the Portal) on any of 11720H, 11759H, or 12032H or any of the other Premiere frequencies _http://www.lyngsat.com/packages/premiere.html
milo2006
Loader: U 4.01
Helsinki
Ok thanks.
Calm down my friend. I made myself perfectly clear - I have three (3) Sports channels in my list. At any given time, they will show various sports, the timetable of which can be seen on the Portal list.
