How do i watch in multiroom
bluenosebryan
dreambox 500s
lancashire
I have a dreambox 500s and was just wondering how do i get to watch the box in other rooms,i live in a ex guest house and in the living room i have an aerial which connects to all rooms in the house but when i try to connect it to the back of the dreambox on the out connector i get nothing,is there anything i can do to get this to work without having to use the video,audio points help would be much apreciated thanks..
Didn't think the Dreambox 500s had an RF modulator, are you connecting to the IF loopthrough?
bluenosebryan
dreambox 500s
lancashire
The dreambox has a scart ,3 phono (yellow,red,white) dish in and next to it the same connector as dish in saying(out)the only way i think i can connect it to other rooms is if i put in all new leads around house and use the phono(red,yellow,white)thats what i call them to replace all the old aerial lead but i was hoping i could somehow use the existing aerial lead,i hope i dont sound to confusing because im confusing myself but thanks for the reply anyway rolfw
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
You could connect a video sender to the scart socket on the 500. Think thats your easiest option.
satelliteman
An RF modulator will do it.
Connect the main TV via scart from DB and feed the modulator from the phono outputs. Then output the modulator with co-axial and feed it up to loft where you can install distribution amp to many rooms.
bluenosebryan
dreambox 500s
lancashire
Thanks guys for your help i will try these methods in a while but thanks again :-thumb1
