how to blind scan in skystar hd2?
krishn
dvb s2 usb for pc
india-gujarat
hi friends,
I am using skystar hd2 with dvb viewer pro license version and dvb dream for watching channels.
I am looking for the software which can scan all available tps from the pointed satellite. is it possible to blind scan? please tell me if any software of utility available.
:-worship
starman345
10' c/ku dish Bullseye II feed, Gbox 3000, 90cm Dish, SG-2100,
Prof 7301 PCI
TBS 8922 PCI
TBS 6925 PCI-E
New Brunswick Canada
krishn said:
hi friends,
:-worship
The only hardware blindscan card I am aware of is the Skystar V2.3. Its not made anymore and they are getting hard to find. You can do a blind scan with your card in Transedit but it is a software blind scan. You need to input the parameters and it is very very slow, not really useful if you are expecting blind scan like a stb delivers.
krishn
dvb s2 usb for pc
india-gujarat
_http://www.dvbviewer.com/griga/TransEdit%20E/MainWindow.html
have anybody tried blind scan as given help in link?
will it really work?
No live links, read the rules krishn.
Yes, I do use it occasionally, but as the previous poster said, it is very slow, particularly if your parameter variations exceed a hundred or so - which will be the case if you want to scan a sizeable portion of the tuner range.
If using for feeds, best to try just one or two most-used feed SRs at a time to cut down the time taken. 27500 and 22000 SRs on the majority of broadcast satellites will keep you waiting until kingdom come.
krishn
dvb s2 usb for pc
india-gujarat
yes, I have just tried. it is taking too much time.
any pci card available with blind scan inbuilt? or any good fta blind scan receiver?
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
or usb external
iwol
satlook micro
yorkshire
or usb external
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Krishn...
As Starman has already told you ..
The only hardware blind scan pci card ever made (afain) is the Skystar2 Rev2.3 (SSD) only ..
No longer made ..and getting hard to find second hand..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Krishn...
rgds
VS
krishn
dvb s2 usb for pc
india-gujarat
I have already bought it and using it right now.
krishn
dvb s2 usb for pc
india-gujarat
