the idea is to take your v1.2 irdeto smartcard and duplicate it with a
subscribers card.
the working card...................
read all the data from this card,ascii and hex ser no's,hmk,mkprov00,mkprov10,pmk 00,pmk 10,allpk's prov00,all pk's prov10,and all the channel id's.i use cardblaster 92/93.
the 1.2 card.......................
kill the card....firecard 146,there should only be an atr on the card
and maybe the numbers '20' in other fields.
use fmcard 3/4 to write clone crd with the info you took off subscribers card.
write the crd to 1.2 card and verify info is ok on card.
write the channel id's to the card now.
your card should work now!!!!!!!!!!!
subscribers card.
