how to connect sattalite reciver with pc
badajoz
my sattalite is metronic
and my pc is pantum 3
spain
Hi there
actually i am a new in this field and i have no any idea about reciver pc connectivity ,but i am hoping to find someone to help me by giving some ideas about connecting the the reciver with pc.
for your information i have Metronic reciver (with 9 pin hub) and a very old fasion pc ,so i wonder if any one can answer these questions
1- how to connect the reciver with pc
2-the recommended cable for this connection (with the info writen in rear panel of the reciver RS232 directlly under the hub mentioned above.)
3- the rcomended software which enable me to upgrade the system of the reciver .
4- where can i find Metronic last updated software
5-is there any master software can do the process of the transformation of the data for the any sattalite disregard of the typeof the reciverfor example ,a software which can make the upgrade for the reciver system if it is Metronic ,nokia or any other type.
thanke you .
best regard
HB13DISH
Retired Mod
Middle East - Israel
badajoz said:
Hi there
Use a null modem cable
Search the internet
Search the internet. Start with the maker website.
No. Every receiver need a dedicated software.
Using the wrong software can kill the receiver
thanke you .
best regard
Please see answers above.
badajoz
spain
Hi HB13DISH
THank you for respons
can you just give some info about maker website.
and what is it and what can i find on it
other question
is there a diffrent between the software of the specifide reciver softwae for the system itself and the software which fullfil the download process from the internet to the reciver
thanks
best regard
HB13DISH
Retired Mod
In this forum we don't use titles, but just for your information it is a Mr. (have deleted the titles from your post)
You have to search yourself the internet, as I don't have your receiver.
No idea what your other question means.:)
