How to receive DVB-S2/H 8PSK channels
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
There are some channels with DVB-S2/H 8PSK standard - 13E, 11334H/27500(Premium Calcio HD, Premium Cinema HD, Premium Play HD); 11373H/27500 - Canale5 HD for terrestrial transmitting. How to receive these channels - with bigger dish or special receiver? Are there receivers with this standard, which models?
The DVB-S2/H8PSK standard is used for mobile TV services, e.g cars, portable TV. There is software such as that at _http://www.mobile-dtv-viewer.com/ that can be used with terresrial PC cards, but not as far as I know with satellite receivers/cards, so the services on those frequencies are not viewable.
popovp
Varna, Bulgaria
Thanks!
There are some DVB-S2 PCI cards H-8PSK standard - TBS8921, Prof Red Series DVB-S2 PCI, but can't find receiver(box) with similar specification.
_http://diablosat.net/-/51-tbs-dvb-s2-pci-8921-.html TBS DVB-S2 PCI 8921
_http://www.proftuners.com/prof7300.html Prof Red Series DVB-S2 7300 PCI | proftuners.com
[nolink]Admin[/nolink]
BlindFaith
TBS 5925
Afaik DVB-S2/H 8PSK is not a standard. These transponders use a different PL scrambling sequence. For special tv-cards (e.g. TBS6915/5925) the sequence can be set by Crazyscan. In addition it's MIS ;)
_http://www.tbsdtv.com/forum/viewtopic.php?f=25&t=383&p=25978#p25978
Thanks. Didn't read the whole thread with pointers to the new files. Promises further investigation.
Crazyscan 1.0.1.53 with PLS Code searching by specified number works well on the Mediaset TPs.
11372H with PLS root 8 finds Mediaset Canale 5 HD.
11432V, same PLS root.
