thiru
- Dec 17, 2007
- Age
- 41
- C-BAND feed connected to Wintv Nexus-S card.
- India
Hi all,
I am using WinTv-Nexus-S card, with ku-band feed connected to it.
I am using linux-dvb-apps scan utility to scan the channels.
With ku-band signal i used the following command to scan the channels.
#scan Hotbird-13.0E
(Hotbird-13.0E is initial tuning data file)
This is working fine without any issues.
Now i started using C-Band signal.
when i try the same command, it says tunning failed.
I tested the signal in the feed by connecting it to a TV. It shows the following channels.
Gyandarshan, Eklavya, UGC-CEC etc...
So Please help me to fix this problem.
Thanks for ur help in advance.
Regards,
Thiru.
#scan Hotbird-13.0E
Regards,
Thiru.
