How to update HIVION 9090x please
Aligg
Hivion 9090x box
Ireland
Hi All
I have HIVION 9090x and need to update the software, I tried every thing but had no luck, I maybe doing some thing wrong, can some one help me please:(
I downloaded EMUpgrade V2.24 and searched for the software in the net, my Box is Model ID A126 H/W Version 1.00 S/W Version 11.20, so the closest I got is S0fa126_100_1156_x.sgn file I connected my RS 232 cable to my PC and Sat box, started EMUpgrade seclected COM1 and pressed Browse and selected S0fa126_100_1156_x.sgn and pressed start, turned OFF then ON my Sat Box, but no new update....
Any help is appreciated.
tamazgha2003
dreambox 500s
tamazgha
try this way ,see picture
Aligg
Hivion 9090x box
Ireland
tamazgha2003 Thanks for your relpy
I did the same but what I am not getting is the blue broken line moving and telling you how far downloaded and i cant see at the bottom of my EMUpgrade the white window where it says COM 1:115200,N,8,1 all I see is black window...
when I press start nothing happen
any ideas :confused
Aligg
Hivion 9090x box
Ireland
tamazgha2003
I think my problem is EMUpgrade, it is not working when I load, I have attached a word file with pictures of what I am getting when I try to use EMUpgrade...
Help any one knows the problem:confused
Aligg
Hivion 9090x box
Ireland
I think the attached file did not work on last reply
not sure why it will not work, anyway the EMUpgrade is my problem, it will not work...
any ideas
tamazgha2003
dreambox 500s
tamazgha
maybe u have t use a resetfile first
try this site
h**p://www.allsatsw.com/
h**p://www.kokoom.com/kandahar/
ps.: check your transfercable,you need a nullmodemcable
rabie
i want to update my reciever hivion 9090x
middle east
can i get the loader and last updated information for my hivion9090x pls
jeddah_j
HIVION 9090X
H/W 1.00
S/W 11.56
JEDDAH
dear same problem with me too , my system is
HIVION 9090X
H/W 1.00
S/W 11.56
I CAN REUPLOAD THE DATA FROM RECIVER TO COMPUTER. BUT I AM UNABLE TO DOWNLOAD DATA FROM COMPUTER TO RECIEVER.....DONT KNOW WHY
CAN U TELL ME THE PROCEDURE..PLEASE
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
Try the Pinoy Court forum; there should be a link(s) to various sites for Hivion software and support. (Hope reference to the other forum does not break any rules here)
tamazgha2003
dreambox 500s
tamazgha
all hivion
http://www.hvsatsw2006.com/
itzme
hivion 9090x
lhr
i have the same problem n dunno wot to do ... i can upload data from stb to pc but m not able to transfer from pc to stb.
any one with new suggestions or ideas ??
wot hapnd to u guys who have posted above me ? problem solved ?
