how to writer
Blade2
can someone tell me how to writer the eeprom and flash for blue tit card
Yes, download the latest Titanium progger software from the utilities section, start up your programmer in phoenix mode, 3.58Mhz, then insert the card and fire up the Titanium Progger software using the green button.
Once you've done this, press erase, this should clear the card and leave it with the basic operating system.
Press the load flash button and select the flash file from the browse window and then do the same for the Eeprom, press program and it should update the card for you.
Blade2
sorry i ment in as in write the code for it or is there something like a template
Not convinced that it is particularly easy, otherwise there would be more versions of the files around, perhaps someone with a bit of file writing experience may be able to answer you in detail. :)
