You can program any goldwafer or Funcard with a so called "6in1" Code, available on any downloadcenter. You will need a programmer, any cheap usb programmer will do.
The card then goes into the Humax Cardreader. It acts like a "starter card",it is not decoding anything,it just lets the Humax emulator go to work.
That brings us to the next point. You will need to put the Tux to Humax Software on to the reciever, followd by the aktual HOT Patch (5.7 at the moment).
After all that,and after you changed the settings in the HOT Menue to "Card and EMU" you will find, that your reciever will decode all kinds of channels,including the swiss package on 13 east hotbird. You will not need your original card nor a viaccess CAM.
The Humax 5400 is one of the best recievers ever build,extremly stable and very fast.I have two myself and did not find anything better in the last 5 years. Depending on the satellite you tune in (it also supports a motor) you get about 2400 Channels, a good 300 of them in English, dozens of movie and sports channels and of course plenty of "adult" entertainment.
The loader version and ID number you posted means, that you have a 5400z patched to 5400,if you hit MENU check if the first entry is HoT, if so, you already got all software you need and only need to check for the newest version (5.7)
You will need a Nullmodem Cable and a Windows computer. All Software is available free and extreemly easy to get.
All this might sound complicated,it is not. Believe me,once you looked around on the net for the Humax 5400,it is so easy,it should be illigal
Well, have fun with it and hold on to it, no other reciever is as easy and fast as this humax, even if you pay 3 times as much. Only thing missing is a harddrive but then,you can't have everything.
greetings
Chris
