humax CI 8100 - help needed
ciaran
hi
i have the above box but want to search for a satellite that isnt currently on its satellite list....can i manually add satellites to my reciever/and will this added satellite show up when i move the dish...or is it a matter of needing to update the software for the receiver?
i have lost my manual...and cant find it online...
any help appreciated.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Your manual is here:-
_http://www.humaxdigital.com/global/products/new_manual/CI8100200GB.pdf (9.4Mbyte !!!)
Had a quick look through and it looks like that you can manually add satellites and their transponder information, so a software update shouldn't be required.
Although it is worth a look on the support site anyway, as software may have been released to fix any bugs, also you might be able to down load and up to date satellite/transponder list, to save you doing it manually.
Robbo:-sugar
_http://www.humaxdigital.com/global/products/new_manual/ci-8100pvrgb.pdf Should sort you out. :)
Damnation, must type more quickly. :-lmao
