Humax weak signal
zzaffy
Skye
Buckinghamshire
I have a Humax box. I have a sky dish.
I have plugged some cables in.
The screen says: The receiver is not receiving a signal or the signal is too weak.
There are more holes for more cables. Do I need more cables? Please see pics.
Was the Sky dish previously used with a Sky Q system? If yes then most likely you'll need to change the LNB (the part of the dish the cables connect to) for a mk4 Sky quad LNB. A photo of the dish and LNB will help confirm this.
zzaffy
Skye
Buckinghamshire
Yes. I am just about to send the equipment, Sky Q Hub and Sky Q 1TB, back to them.
I will take a photo tomorrow.
Gladstones
Zone 2 Fixed at Astra 2
Gibertini XP 75 cm fixed at 30 west
Gibertini XP 1 meter motorised 53e to 27.5w
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
if its hybrid lnb swap the cables to empty ports on lnb if its got only two ports its wideband lnb which only works with Q then new lnb needed
zzaffy
Skye
Buckinghamshire
Thank you Gladstones. Can you repeat that please. Maybe using different words.
SkyQ uses different lnb's (the bit on the dish) to other receivers. The internal electronics work differently how they handle the signals. The exact differences dont matter but what it means is that a none Q receiver wont work with Q lnb's.
Some lnbs have extra "normal" ports on them so you can just swap the cables over onto them. If not you will have to buy a replacement none Q lnb
zzaffy
Skye
Buckinghamshire
Will these pictures help to identify if I need a new lnb or if I can swap the cables around? Thanks
That's a Sky wideband LNB, the only Freesat boxes that'll work with it are the 4K models. As you have a Humax you'll need to replace it with a Sky mk4 quad LNB, they can be bought new for under £15 on Amazon.
zzaffy
Skye
Buckinghamshire
Ozumo thank you so much. Was worried I'd have to climb a wobbly ladder to fix something that I know nothing about,
No problem, be safe up that wobbly ladder :)
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Sorry was busy at work
analoguesat explained what I meant
Remember sky Q lnb uses 37mm holder
But normal /mk4 lnb neck is 40 mm so buy new lnb with holder.
holder is a plastic bit holding lnb.
New lnb is available at screwfix as well.
That is not strictly correct, both Raven designs have the same LNB profile though one manufacturer (Labgear) is supplying a feed adapter with a 40mm clamp and their own single, twin or quad LNB.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
When I changed lnb on sky q zone 2 few years ago I had to change the holder because 40 mm lnb did not fit.
