I think i have shot my tit and killed it
bigboygazza
hi
i am have lots of problems with my tit card, i am useing a smartmouse/pheoniex programer with a blue tit its ment to be v 1.06, i am useing titiaum card progger 1.10.2, every time i start up the program it says unsuppoterd os found and i have erased it and its says its back to virgin state but it still says unsuppoterd os found i have tried everything i have tunerd off the fifo buffers i can get passed the trapcode part i have absolotly no more ideas on what i can do so if any one can help it wold be very much thanked
chears bigboygazza
Razor
Retired Mod
Ireland
Change down to OS103, and see if that helps.
bigboygazza
1 i dont know how. 2 dont u have 2 have a os on the card befor u can put anouter one on there
Try using TJ's Titanium Progger, it should be in the utilities section.
joshjess
I used to have an infinity phoneix usb programmer and got the same problem, so decided to look around and found a duolab programmer from www.unapit.com and used it first time with my blue tit card with v1.06 and it programmed first time and unlocked all s** it**a channels without any problems using a xcam v.104.
Hope this helps
bigboygazza
thanx rolfw
i tried useing the progger but no success it would not trap the card i left it for 50 mts thanx for your help
bigboygazza
i have now restored the card back to virgin state but it still says unsupported os found and the card still has no atr
is there anyway to put a atr number on there so i can change it to up date the card to a 1.06
Razor
Retired Mod
Ireland
There are some files on here in T24 section, and on other boards. Look for one called Tit editor , or TMB editor as there is a way to bring back to life ..dead tits.
See below.
CHANGING THE ATR ON THE CARD
You can change the ATR on the card,(do this only
if you have problems with your card...)
To change the ATR,open the eeprom file with TMB Editor,
click on Card_Menu and enter the ATR you want to use,
and click on write.
3 conax ATRs are available:
3b 24 00 80 72 A4 45 (Default ATR,Recommended for Force machines)
3b 24 00 30 42 30 30 (Recommended for MHW rental boxes)
3b 26 00 80 72 A4 45 (The 3rd alternative :)))
Razor
Retired Mod
Ireland
The above is taken from the readme of a TMB file.
bigboygazza
i tried the tmb editer and the tit editer it keeped saying no card!!! and thay bouth didnt work any more help anyone
bbgazza m8
my card is the same its ya flash thats knackered
so looks like we got a couple of ice scrapers for the winter
regards
dave
bigboygazza
thanx dave for letting me know onely thing is that ice scraper costs a lot of money also i left it in the proggrammer for 3 days and it melted the plastic around the chip. i have now been waitng 2 and a half weeks for my new one to arrive i am dreading the same thing happening agian time will tell
bbg m8 i have got an atr but try to up-grade it just keeps say error failed to write flash so iam after another card if i can get one ????????
dave
