buset07
- May 31, 2008
- Age
- 59
- None
- UAE
I'm a new in this area. Just bought that model, and completely confused :
1. the model has USB 2.0 and RS232 ports, but the manual says that to upgrade the software, use the later. Is there a problem if I use the USB one for an upgrade ?
2. most of the keys bin I found are for Humax 5400. Can I use that keys bin for my iCord IRCI-PVR ?
3. can I use / upload the emu using ToH34_Hotxxx.zip ? Are they specific humax model ?
4. some emu support the 'auto-update'. Is there one for this model ?
Thanks for your help.
